C-113 head gasket
Rob in Ore
05-31-2004 13:47:12
I am putting the head back on and the new gasket says "sealer/retorque required".
My question is what should I use for sealer and when do I retorque?
I tried to search the archives but the search utility is down for maintenance. Thanks in advance for your help.
The Red Baron
05-31-2004 18:56:45
 Re: C-113 head gasket in reply to Rob in Ore, 05-31-2004 13:47:12
Going from memory I believe the specs I finally determined for my F-12 C-113 was 100 ft lbs. I crept it up from 60 lbs, 10 lbs at a time going in proper sequence. I finally stopped at 95lbs, since it just seemed to be getting to the point where I was becoming concerned (perhaps needlessly so.) It sealed just fine and I have never had any trouble with it. I used some type of Permatex paint on copper head gasket sealer instead of the stuff you spray on, and again it seemed to work just as it should.
Farmall A puller
05-31-2004 14:07:16
You can go to the parts store and buy a spray can of copper gasket (aerosol can). This is specifically designed for cylinder head gaskets. As far as re-torque on the head, after the initial torque, run the tractor up to operating temperature. Then take off the valve cover and re-torque all the head bolts to spec.
Tommy H
05-31-2004 14:10:51
 Re: Re: C-113 head gasket in reply to Farmall A puller, 05-31-2004 14:07:16
I think a while back we came up with 75lbs got no leaks, but I think 80lbs was spec.
70lbs caused leaks for some people
Peabody
06-01-2004 07:55:50
 Re: Re: Re: C-113 head gasket in reply to Tommy H, 05-31-2004 14:10:51
Remember to check valve clearance after retorqueing.
