slight miss in engine
Hunter
05-31-2004 15:37:16
On my 340IH I have a slight miss at idle and when going down the road on a level grade or when going down hill. It runs fine when going up hill. I've replaced wires plugs cap rotor points condensor, checked for vacuum leaks, tinkered with carb. The only thing I have not done is checked the distributor timing. Any ideas? thanks
BIG JOHN
05-31-2004 15:54:46
 Re: slight miss in engine in reply to Hunter, 05-31-2004 15:37:16
Check your valve adjustment. You could have one cyl. that has a valve not adjusted quite right. This is what my problem was when I had the same thing going on with my A.
Good Luck
