Farmall C Questions - Hydraulics
Mike@NY
05-31-2004 16:44:56
Hey everyone. Got another question here. I recently got my Farmall C running, and I had to rebuild the hyrdraulic pump, due to that the previous owener ran it dry. I put new seals and gaskets into it just to be on the safe side. I was using the C today, and when I started the hydraulics worked fine, but when I was done, there was no fluid left in the resivoir. I wasn't using the hydraulics during the day. I am guesing it leaked through the timing into the crankcase, as that has been known to happen. Plus I didn't see it leak externally. Is there anything that I can do, short of another rebuild kit, which wasn't sheap, to solve this problem? Thank you for your help.
gene b
05-31-2004 19:37:15
 Re: Farmall C Questions - Hydraulics in reply to Mike@NY, 05-31-2004 16:44:56
Check the journal where the seal fits it probably is worn and the hew seal cannot stop the leak. Get a speedy sleeve and put on the shaft where the seal fits and you will be good with a new seal.
Dave_Id
05-31-2004 16:55:59
Replace the o-rings in the pump
