Plow Rope
Dale
05-31-2004 21:05:24
Where does the plow rope holder bolt on at?
1950 Farmall H
gene b
06-01-2004 03:01:36
 Re: Plow Rope in reply to Dale, 05-31-2004 21:05:24
Either one of the rear bolts that hold the seat pan. Depends on whether you are right of left handed might determine which side you would use. We always used a short piece of wire on the bracket then to the rope so when you hit something and the trip on the hitch let loose the rope could pull loose from the wire.
