Tire Paint and cracks
FC
06-01-2004 05:29:19
In the past I have read posts recommending a tire paint which will at least help fill some cracks and make the tires last some longer. I see Miller Tire has some, is this the stuff, or is there another one better? The tires on my C are weather cracked pretty good, but are holding air, etc fine and just want to fill some of the cracks, and make them hold up a little longer. (working tractor) Anyone with any experience with this stuff, and how does it do with the cracks?
Peabody
06-01-2004 06:35:15
 Re: Tire Paint and cracks in reply to FC, 06-01-2004 05:29:19
The Miller Tire stuff is the right stuff. It made my Super C tires look new from a distance. It does help fill and hide the smaller cracks. I was well-pleased with the results. If you go the the "Articles" Section to the left, under "Research & Info," you can scroll down to the bottom of the list and there is an article on "Black Tire Paint" under the "Product Reviews" section. It is a good article. Don't buy it by the gallon, unless you've got a large fleet you want to paint. They sell it by the quart, you mix it half & half with water, and A LITTLE GOES A LONG WAY. I painted both my rear tires and used probably less than a cup.
