How to remove those stuck wheel weight bolts.
Kevin in Va.
06-01-2004 05:55:05
I've been having a problem removing a wheel weight bolt on the front of my Super-A. Basically, the square bolt head just spun around and around in the depressed seat. Guess that either bolt head was a bit to small or the cast seat was a tad too large! Anyway, the solution was to cut some small steel shims from some scrap and wedge them all in real good to remove the play and not give the bolt any turning room. This worked like a charm! Had the bolt off in no time. Also had to use this technique on a rear wheel where a pervious owner used a hex instead of a square headed bolt to secure the wheel to rim. Hope this helps somebody out.
rustyfarmall
06-01-2004 09:39:42
 Re: How to remove those stuck wheel weight bolts. in reply to Kevin in Va., 06-01-2004 05:55:05
Thank you for sharing that information, you may have just made someones day a lot brighter.
