IH350 fan belt?
Joe in CT
06-01-2004 06:45:46
Just aquired an IH350 Utility with a Lord front end loader. The loader is powered by the front PTO. The fan belt is loose and the fan slips. Does anyone know if the upper pully on the water pump is a variable speed pully which can be adjusted? Changing this belt does not seem to be an easy task... Thanks- eng:175c, gas, 12V
Henry - Jeff City MT
06-06-2004 12:17:16
 Re: IH350 fan belt? in reply to Joe in CT, 06-01-2004 06:45:46
Joe,
What pump do you have on the front? I cracked my Hydronic pump but found a new repacement,6 spine, 1" shaft. Now I need a steering gear. DON'T overload the bucket and try to turn. It will make bad noises!
TDK
06-01-2004 09:15:16
The pulley is adjustable. Loosen locknut and set screw. Turn pulley nut clockwise(facing front of tractor)to tighten, counterclockwise to loosen. May take some soaking with penetrating oil first.
Joe in CT
06-02-2004 04:45:48
 Re: Re: IH350 fan belt? in reply to TDK, 06-01-2004 09:15:16
Thanks TDK. It's going to be stubborn. Tonight I try the "bigger" hammer...
