IH 384 Hydraulics Problem
Justin Robertso
06-01-2004 10:05:16
I have an IH 384 tractor that i use frequently on my small strawberry U-Pick here in Newfoundland. My Problem is that the 3-point hitch will lift just fine on this tractor but will not release the fluid and let the arms drop. The Pump does not strain against itself and continue to try and lift it just works normally going up. Also I have checked the small filter in the front next to the main cylinder.
I have already had this completely apart now twice and cannot find the problem. Any help here would be appreciated i realise that this is not much to go on but as i said any helpful ideas would be greatly appreciated.
Justin
JB
06-01-2004 16:32:55
 Re: IH 384 Hydraulics Problem in reply to Justin Robertson, 06-01-2004 10:05:16
Hi, just a thought is your draft control lever all the way forward ? Or something wrong in the valve body in front of the seat ?
JB
