International 340 Utility Hydraulic System
Scott
06-02-2004 07:53:23
Hi, Just purchased a 340 utility and hydraulics are not working properly. Fixed a bad leak in the steel lines, but need to add fluid. Ordered manuals but have not arrived yet. I see from another posting that the fluid is added in the big pipe plug next to the gearshift lever. Anyone know what type of fluid/ gear oil? Seems like the same oil is used for the trans grease and hydraulic oil.
Are the pumps prone to failure? Hard to rebuild if bad?
Thanks,
Scott
John Humphrey Morocco IN.
06-03-2004 19:11:57
 Re: International 340 Utility Hydraulic System in reply to Scott, 06-02-2004 07:53:23
The filter is on the right side of unit (viewed from the seat) down on the side of the trans case. There is a plate with with 8 or 10 bolts over the filter. if the unit has engine driver Hydra-touch, it has two pumps in tandem. One for power steering and one for Hydra-touch. 12 GPM for normal use and 17 GPM for use with a FEL. There is a conversion so that you can use an late model off the self filter. Gasket here can be a problem. Poor seal lets pump get air and it will growl and shorten pump life.
Novel Idea Guy
06-02-2004 13:19:12
Use Case IH Hy-tran.
You're right, the hydraulic reservoir is the transmission.
