three point hitch aftermarket kit for farmall h 19
john
06-02-2004 20:15:49
IS THERE ANY AFTERMARKET KITS TO INSTALL A THREE POINT HITCH ON OLDER TRACTORS LIKE A FARMALL H WITH A DRAWBAR HITCH AND WHERE CAN YOU FIND IT IF IT EXSISTS.
26Red
06-03-2004 11:31:00
 Re: three point hitch aftermarket kit for farmall in reply to john, 06-02-2004 20:15:49
I have owned/operated both brands below on a H and 300.
1. Saginaw is the best. (Hyd. cylinders included with hitch)
2. Tractor Supply Co. sells "worksaver" brand, which is cheaper, but you still have to buy hyd. cylinders.
3. You can modify your H's hydraulics so you can have up/down pressure on the three point hitch. (which makes it much more handy)
check out this site:
http://www.geocities.com/farmall544/
Randy in NE
06-03-2004 04:15:13
You can try Saginaw County Tractor Parts at www.saginawcountytractor.
