' 40 Farmall M Ignition
Rusty
06-02-2004 20:51:07
Hello,
I have a 1940 M that was stored in a barn since the mid '70s. It is in nice condition & the motor is loose, but over time someone stole the Magneto/Distributor from it.
How do I find out if it originally had a Mag or a Distributor? I already have a Distributor from a junked McCormick W-9, and was wondering if it would work.
thanks,
Rusty
Dick in Fallon
06-03-2004 12:46:52
 Re: ' 40 Farmall M Ignition in reply to Rusty, 06-02-2004 20:51:07
Rusty, there is a magneto for an "M" on ebay,ending in 7 Hrs. Item # 3818481940.
Don't know if you'll get this in time, but thought you might have a chance, current price is approx.$47.00,Dick
jal-SD
06-03-2004 05:58:59
Mags & distributors from A's, B's C's & all the Supers are also the same. IH began to sell both IH & Delco (the right angle ones) distributors to replace mags in the '50's & there are a lot of them out there. You can use any of them to replace a mag. Allis Chalmers also used the Delco's & they will work, too. Any 4 cylinder distributor that has the same flange will work, but you might have to figure out the rotation & match it to your firing order. We've used IH stuff on Case's so if you find a good Case mag, it will work as well, but parts for Case mags are nearly impossible to find. (My $0.02 worth. jal-SD)
H.J. Durham
06-03-2004 05:45:47
Hi Rusty, The distributors from the following tractors will fit the Farmall M: H,HV,MV,W4,O4,OS4,W6,O6 and OS6. They all have the IH part number 353 890-R91. You should be able to find one of these that has been junked.Hal
H.J. Durham
06-03-2004 05:05:30
Hi Rusty, Is there an ignition coil mounted on
the engine? Mags do not have coils mounted externally. The mag coils are installed inside
the magneto. The W9 distributor rotates counter
clockwise. Call a IHC shop they may have a junk
Farmall M or they can look up the W9 distrbutor to
see if it will fit the M. Good Luck-Hal
Will Sick
06-02-2004 21:43:03
If it has a two wire switch it had a distributor. 1 wire would be for a mag. The 40 M came out with a magneto.I don't know if the W9 distributor will work.
