anyone heard of a H with engine oil dipstick?
red reaper
06-03-2004 05:15:40
I picked up a H with a locked up engine yesterday,and noticed it had a dipstick for the engine oil,cast right into the block on the right side.Looks factory,but I've never seen one with one. Does anyone know when they started putting them on? or is it a different engine? its a 48' model. Thanks
Red Reaper
06-03-2004 20:26:28
 Re: anyone heard of a H with engine oil dipstick? in reply to red reaper, 06-03-2004 05:15:40
Thanks for the help guys,I'll have to do a little investigating when I go to pick it up.Interesting.
max adams
06-03-2004 19:24:35
Reaper i have an H, a 51 and it has a dip stick.
it appears to be factory? as far as i have been able to find, it's original.
LAW/MN
06-03-2004 09:50:20
When our 1942 H was o'hauled in 1959 we installed a dipstick, and after painting appeared as a
original feature.
Novel Idea Guy
06-03-2004 07:44:32
Dipsticks weren't standard fare on tractors until the 350, even though the bosses were cast into the engine blocks right from the get-go. Combines had dipsticks because the oil pan petcocks were not easy to get to.
Either this is a combine engine, an engine out of a 350, or someone drilled the boss during an engine rebuild, or at least while the oil pan was off. You don't want to go drilling holes in your engine block while it's in the tractor.
Van in AR
06-03-2004 21:40:37
 Re: Re: anyone heard of a H with engine oil dipsti in reply to Novel Idea Guy, 06-03-2004 07:44:32
I have a 1955 300 with the petcocks, also have a 1956 300 LP with a factory dipstick.
Van
rustyfarmall
06-03-2004 05:46:45
As far as I know all Hs had the area for the dipstick, it just was not drilled out. It would be a fairly simple matter for someone to drill a hole and then install a dipstick. There may even have been an aftermarket kit for this purpose. Also, I don't know for sure but I think some of the stationary power units may have been equipped at the factory with a dipstick. You may want to compare the casting codes and serial numbers to determine if the engine is original to the tractor.
farmall kid in pa
06-03-2004 17:10:02
 Re: Re: anyone heard of a H with engine oil dipsti in reply to rustyfarmall, 06-03-2004 05:46:45
me and my fathere own a tractor repair bussiness and in some of the books i have read the H's and M's in cotton pickers had dipsticks because u couldn't reach the petcocks if the picker was on the tractor. but it may also be a combine motor. also another thing that is weird and people will say it is not the original thing are disk brakes on an M (they could be bought as an accessory)(according to the parts and repair manual at my shop) if u like i can scan it to prove it.
