oil on brakes Super A
Deane
06-03-2004 15:36:29
I need the part number for the seals on a super a (1952) that always leak on the brake shoes. Neighbors tractor and no parts catalog
VAJerry
06-04-2004 06:46:50
 Re: oil on brakes Super A in reply to Deane, 06-03-2004 15:36:29
If the old seals have grooves worn in axle NAPA has sleeves to fix it. Or the new seals will leak too.
Haas
06-03-2004 18:02:01
While you have it apart, replace both the final drive seal and the transmission (differential) seal. Transmission seal is IH number 288864 R93, National 410060 SSR. Final drive seal is IH 71597 C91 (new number), national 410083. If you replace the final drive seal, the drum brake drum must come off and the pinion shaft out, so you'll also need gasket IH 1342398 C1, which is for the cover on the final drive over the pinion shaft acess hole. Pretty good job to get the final drives off to rework the brakes and replace all this.
lee
06-03-2004 16:21:17
It's maybe a $5.00 part. Much easier to get than get to.
