Help me identify this tractor
Jim
06-04-2004 11:20:02
I just acquired an old Farmall tractor. The decal says Super C on it but the serial number is FC 28079 and it doesn't seem to match up with the serial number guide that I have for super C's. Is it a regular C? Also, it has no power take off shaft on it, just a plate bolted over where the shaft would come out. Is there any way of telling if this is any kind of rare tractor or just another C? Thanks for any replies!
Red Dave
06-04-2004 12:23:19
 Re: Help me identify this tractor in reply to Jim, 06-04-2004 11:20:02
FC 28079 is a 1949 Farmall C. A straight C, not a Super. Like Randy in NE stated, Super C's have 6 digit serial numbers.
Tommy H
06-04-2004 15:22:20
 Re: Re: Help me identify this tractor in reply to Red Dave, 06-04-2004 12:23:19
wow, I have a 1949 C as well!
Randy in NE
06-04-2004 11:32:48
The C's are going to have a 5 digit serial number while the Super C will have a 6 digit serial number. The C has bank brakes where the Super C has disk brakes. The brake pedals on the C are fairly straight while the Super C has a more pronounced curve to them. The gas tank on the C sits right down on top of the hydraulic unit while the Super C has about 1-2" space below the gas tank. I think that the Super C will have a water pump but this could have been added to a straight C. Just a couple of the differences.
David B
06-06-2004 09:22:44
 Re: Re: Help me identify this tractor in reply to Randy in NE, 06-04-2004 11:32:48
Didn't a Super C have a bigger motor than a C? Didn't a C have a C113, and a Super C had a C123?Isn't that the reason for the taller radiator, grill, and the higher spacings everywhere else?
Thanks
Jim Becker
06-06-2004 18:53:25
 Re: Re: Re: Help me identify this tractor in reply to David B, 06-06-2004 09:22:44
Yeah that is almost true, but when you are trying to tell the two models apart the extra 1/8 inch cylinder bore isn't that helpful.
Tommy H
06-04-2004 11:47:09
Super C had a temp gauge for the Hydraulics, I think?
