Rear End Gear oil
Super AV Tom
06-05-2004 06:30:13
What weight oil is used in the rear end of a 1949 Super AV? I would like to change it and install my PTO assembly but I'm not sure what to use. Any help would be appreciated.
Tom
Jim
06-05-2004 16:35:27
 Re: Rear End Gear oil in reply to Super AV Tom, 06-05-2004 06:30:13
For about the same price you can get 85W140. Works great on older tractor differentials.
Russ
06-05-2004 19:03:19
 Re: Re: Rear End Gear oil in reply to Jim, 06-05-2004 16:35:27
Rear end lube; Use the lighter weight product if your using the tractor infrequently and may use it a little during the cold and dread of winter.
Use the heavier weight product it you intend to use the rig unmercifully during the hot weather over long hours of use. May find getting the 85W-140 product inconvenient in your area.
CNKS
06-05-2004 12:25:52
I just bought some 80W90 at Walmart this morning for my Super A -- figured it is probably better than what came in the tractor, certainly better than the 50% water solution that came out.
Dave_Id
06-05-2004 06:51:54
80W-90, Some guys like using the real heavy stuff, I think it is 140W150, or something like that
