Antifreeze spots on edge of head
waynekittler
06-05-2004 12:38:52
Did the tappets on my IH 200 cu inch gas Monday. Went to put the valve cover gasket on Friday and there were three one/quarter inch buttons of anti-freeze in a line on the lip where the gasket sits. Does not seem to be a visible crack through the head at this spot. Did have some sludge on the inside of the cover on the tractor seat end of the valve cover. Been 14 years since I took the cover off.
Can I run the tractor without causing water damage to the engine? Water level in the rediator has been prety good.
Chris Brown
06-06-2004 10:58:41
 Re: Antifreeze spots on edge of head in reply to waynekittler, 06-05-2004 12:38:52
I am not sure exactly where your antifreeze droplets are. But from what I can tell ,it sounds like condensation drops,possible from a leaking head gasget. Try re-posting your question and try to be a little more descriptive.Word it like you are talking to a dummy (like me) Sorry I could'nt be of more help.
