Hydrilic block on Super C
wildman
06-05-2004 18:37:30
In front of seat on tractor hoses come from the front and hook to block at seat and then lines screw ib block and go to lift in back. What is this block and what purpos does it serve. what do you call it it I try to get one. Or can I run lines straight through. Any help will be appriciated. Thanks
wildman
06-06-2004 07:49:33
 Re: Hydrilic block on Super C in reply to wildman, 06-05-2004 18:37:30
Thanks for info great help.
Brian Schmidt
06-05-2004 19:35:03
It is called a load check. Basically a double check valve. It takes pressure on one side to shift it to allow the return to tank to open. This keeps your hydraulics up on the older valves that do not have close tolerances. It prevents drift. Generic ones are available at hydraulic supply houses or you can shop the bones yards and swap meets for one.
