544 C-200 gas manifold torque
Kent
06-05-2004 20:11:29
I am putting my C-200 engine back together and have found some of the torque specs but don't have one for the exhaust/intake manifold. Does anyone know what the torque is?? The studs are 3/8" coarse thread into head and fine thread for the nut. My I&T book don't cover much on the engine. Thanks, Kent
ChadS
06-06-2004 07:35:04
 Re: 544 C-200 gas manifold torque in reply to Kent, 06-05-2004 20:11:29
Dont go beyond the torque spec for a 3/8 bolt, 35-40 ft lbs should be plenty tight. Start in the middle, and work your way outwards. Chad
Kent
06-06-2004 18:34:28
 Re: Re: 544 C-200 gas manifold torque in reply to ChadS, 06-06-2004 07:35:04
ChadS, That is about what I was thinking, I wanted some "positive reinforcement"!! I have a stud at one end that is Heli-Coiled and the other end has the stud welded in. I wanted to be extra careful and stopped the torque at 25ftlb this afternoon. The studs seem like they are grade 5 or more. I took one and tried drilling on one and they are pretty tuff. I will watch the manifold real close anyway because of having it welded back up. Thanks, Kent
