240-U Transmission Hydraulic Case
Jerry in WA
06-05-2004 22:02:38
Does anyone have any idea where the drain plug is on a 240-U? I have looked all over and I can't find any place to drain the darn thing. I must be blind or tired or both, I know it has to have a drain plug.
Thanks for the help.
Jerry
Stan(VA).
06-06-2004 05:28:58
 Re: 240-U Transmission Hydraulic Case in reply to Jerry in WA, 06-05-2004 22:02:38
If you're draining the tranny case, it uses gear oil and the drain should be under the differential. If you're wanting to drain the hydraulics, the reservoir is the torque tube and there should be 3 drain bolts pointing out one side on the bottom of the torque tube.
Stan(VA).
Jerry in WA
06-06-2004 07:52:12
 Re: Re: 240-U Transmission Hydraulic Case in reply to Stan(VA)., 06-06-2004 05:28:58
Stan:
I didn't see one under the differential, but there is a bolt on the torque tube that is towards the center that has what I thought was a spacer behind it. This spacer looking thing is silver colored, and located on the left hand side. I'll loossen it up and see what happens. I'll also look again and see if I can find a drain plug under the differential. Unfortunately the shop manual doesn't show where they are.
Thanks for your help.
