Will a 340 Utility Handle a Round Bale Type Hay Ba
D.C. Arnold @ C
06-06-2004 00:07:11
Guess I did not state my question very well.
I would like to know if anyone has experience in using a 340U with a baler making round hay bales.
If so, what size would it handle. Thanks.
Kelly C
06-06-2004 06:59:38
 Re: Will a 340 Utility Handle a Round Bale Type Ha in reply to D.C. Arnold @ Colonial Ma, 06-06-2004 00:07:11
I believe you could with a older round baler.
I have a IH 241 they require 29 HP to roll.
SO you could roll some hay with a 340U now the question is should you.
Those beast of balers are heavy with a full bale on them. You may have to roll till full then drive to a flat spot to unload the roll.
As long as you are not doing a tremendus amount of hay you could get by with it.
TGIN
06-06-2004 04:57:12
That would be asking alot of it .
wolfy
06-06-2004 12:25:31
 Re: Re: Will a 340 Utility Handle a Round Bale Typ in reply to TGIN, 06-06-2004 04:57:12
34
Chris Brown
06-06-2004 10:53:14
I made hundreds of bales with a 241 ih baler behind a regular WD not a 45, Allis Chalmers. I think they are around 30 hp.
gene b
06-06-2004 04:53:29
How many horses are required by the people who made the baler? Thats the first question second is do you have good experience in mowing, right size windrow,hilly ground,what kind of hay?
