656 Ta shot?
656
06-06-2004 16:47:47
I have a 656 with mechanical Ta. When tractor is put under even a small load, it will just stop forward motion. Doesn't help to pull TA back. Only will go if tractor is down shifted. Will stop even in 1st gear if load is big enough. Does it sound as if the TA is completely shot or is there some kind of adjustment that will help?
farmered
06-07-2004 05:00:09
 Re: 656 Ta shot? in reply to 656, 06-06-2004 16:47:47
Check to see if you have "free pedal". You should have about an inch of travel in the clutch pedal before the throw out bearing contacts the clutch fingers. If the bearing is in constant contact the clutch will slip. If there is no more adjustment the clutch needs replacing. Ed
Chris Brown
06-06-2004 17:33:51
Sounds like the main clutch is gone not the ta.
nebraska cowman
06-06-2004 17:30:44
i would guess the main clutch is slipping
