H STEERING SHAFT U JOINT
JON
06-07-2004 18:15:34
I was wondering if any one had a aftermarket part # for the U Joint in the steering shaft on an H.I would like to get one at Napa or some place like that if possible. THANKS JON
David B
06-07-2004 19:46:03
 Re: H STEERING SHAFT U JOINT in reply to JON, 06-07-2004 18:15:34
If the U-Joint is sloppy around the steering shaft (the one the goes to the front through the radiator), shim it up with some brass shim. Works great. just did it to a '42 H.
Haas
06-07-2004 18:29:55
You can get the replacement U joints for the steering shafts aftermarket. However, you will have to cut the steering shaft, as the yoke for the U joint on the rear steering shaft is welded to the shaft. The front side has a woodruff key and a clamp joint. As others said, you can get a kit to rebuild the U joint.
rustyfarmall
06-07-2004 18:21:09
It depends on what year your H is, that same u-joint is bad in my 1940, and a rebuild kit does not exist, anywhere. If your H is a later model, you can get a kit fron Case-IH. In the case of the early models, you replace the entire joint.
JON
06-07-2004 18:33:58
 Re: Re: H STEERING SHAFT U JOINT in reply to rustyfarmall, 06-07-2004 18:21:09
I beleve its a 47
rustyfarmall
06-07-2004 18:38:21
 Re: Re: Re: H STEERING SHAFT U JOINT in reply to JON, 06-07-2004 18:33:58
In that case you should be able to get a rebuild kit for it.
