560 hydraulic preasure
hal
06-08-2004 06:02:00
I have a 560 and I just bought a br740 new holland round baler. the book says that it takes 1500#psi to open the rear gate on the baler. The 560 only produces about 1100# psi. Is there any way to reset the valve bodys/pump to boost the psi up to 1500#, I need to be able to open the rear gate on the baler. Thanks.
Vern MN
06-09-2004 02:40:37
 Re: 560 hydraulic preasure in reply to hal, 06-08-2004 06:02:00
I would not worry about your 560 not being to lift the gate. Give it a try.
Aces
06-08-2004 08:33:50
Hal 560 should have 1600PSI if pump and rekief valve is ok.
Allan in NE
06-08-2004 06:20:37
Hi Hal,
Have you tried it yet?
I think I'd throw away the book, hook 'er up and see what happens.
That tractor will lift itself off the ground and it weighs a heck of a lot more than that gate does.
My view,
Allan
