Order Farmall Cub Parts Online
Farmall Cub stopped
Bill
06-08-2004 17:08:24
My Cub was running good mowing after outting it back together after a 6 year hiatus, but then it started to miss and then finally stopped and refused to start again. I know I ran it about 3 gallons of water short. More leaked out than I guessed. I put new plugs in and still no start. I have to crank it and it turns over the same as before. Any suggestions?
Bigdog
06-08-2004 18:03:04
 Re: Farmall Cub stopped in reply to Bill, 06-08-2004 17:08:24
Do you have spark at the center wire to the cap? It would help if you could tell us what is missing from the fuel, fire, timing triangle.
Battery ignition or magneto?
