300--- 300 utility engine
dave
06-09-2004 04:48:46
Would the engine on both of these tractors be the same? I have a 300 utility and the exhaust manifold I need(comes off the front and exits at the bottom of the tractor) is no longer available.The one for the 300 (exits stright up) is. I would have to cut a hole in the tin and would do that if they are the same engine. thanks dave
Ibby
06-10-2004 03:09:59
 Re: 300--- 300 utility engine in reply to dave, 06-09-2004 04:48:46
There's a down draft manifold on eBay right now for your tractor, or you can use the updraft one. I put an H manifold on my 350U (same engine as the 300). It's a lot stronger setup with the exhaust pipe supported on both sides by the casting. I've broke more than 1 down draft or front exit manifolds in the woods on high stumps and low limbs. The H manifold has held up great.
Aces
06-09-2004 04:54:40
Dave They are the same some had exhaust out the top
