W30 Steel Wheels
Doug in IL
06-10-2004 11:54:04
I'm starting to look for a set of rear steel wheels for the W30 I'm working on. My question is if the wheels from a 10-20 would work? Or are the axles different? Thanks!
Mike Androvich
06-10-2004 13:59:24
 Re: W30 Steel Wheels in reply to Doug in IL, 06-10-2004 11:54:04
The wheels are different between a 10-20 and W-30. The W-30 wheel has a dust shield on the inside hub that helps seal out more of the dirt and dust that fall off the wheel. The 10-20 wheel lacks this feature. The wheel from a 10-20 will fit on the axle, but this seal will not work. In a pinch, I think you can use the wheel, but it won't be right. The front wheels are much the same. They look like an exact match from the outside but they also have an extra sealing mechanism.
