paint code for H
Dale Lusti
06-10-2004 15:37:56
Does any one know the ppg paint code's for farmall red and the silver on the wheels of a Farmall H ?
sammy the RED
06-11-2004 07:52:06
 Re: paint code for H in reply to Dale Lusti, 06-10-2004 15:37:56
Most of the guys paint the rims aluminum.
CNKS
06-10-2004 19:39:08
There is no paint code for the silver, as the rims were galvanized. Many opinions on this but I use some silver argent stuff from PPG -- actually it's a GM Rally wheel color, has a slight grey tint to it but looks ok to me --PPG 8568. If your H was built prior to 1949, the color is IH 50 (not available from your Case-IH dealer -- PPG 70019, DuPont 7410. Post 1949, IH 2150, available from your Case-IH dealer, or PPG 71310 or DuPont 96766/6951 AL.
Dale Lusti
06-11-2004 04:49:27
 Re: Re: paint code for H in reply to CNKS, 06-10-2004 19:39:08
CNKS thanks for the info on the paint code's. I'm restoring a H to use with a Woods mower.This should keep me busy all summer.
Dale Lusti
06-10-2004 19:34:42
Rudi thanks for the info on the paint. The only thing is There must be ten different reds. Also I did not see the color silver.Maybe the rims are not originaly silver. My H is a1946 model can any one be more specific.
CNKS
06-10-2004 19:43:32
 Re: Re: paint code for H in reply to Dale Lusti, 06-10-2004 19:34:42
Your post came up while I was typing, there are only two IH reds still available, what you want is IH 50 since you have a 1946, you can use 2150 if you want to -- Rudi's site may list companies other than PPG or DuPont, also.
Rudi
06-10-2004 18:04:40
third party image
Dale:
I know that you have an "H", but a Farmall is a Farmall after all :-)
If you click on the link below, then on the Paint, Decals and Other Finish ?'s link, it will take you to the paint chart.
The paint codes are there, as well as the Paint Committee Decisions.
Hope this helps.
