IH 1300 Mower Help
Frank7
06-11-2004 04:06:43
Purchased a 1300 fast hitch sickle mower thatI want to put on a 560. The mower has a 4' chain that has a clevis, and a heavy triangle piece of steel with a hole through it. What I believe I need is a bracket that mounts on the side of the tractor which holds a cylinder. Checked w/dealer & parts yards ; no luck. Thanks in advance.
Bob
06-11-2004 07:58:40
 Re: IH 1300 Mower Help in reply to Frank7, 06-11-2004 04:06:43
The chain should fasten to the tractor in a way that when mower is lifted the chain will pull thus raising cutter bar. Had 3pt. IH which I think was a 1300, it had cable that hooked to drawbar. Anyway try hooking it to a low part of tractor in area of lift cylinder base.
Evan350
06-11-2004 21:16:57
 Re: Re: IH 1300 Mower Help in reply to Bob, 06-11-2004 07:58:40
I don't know how much a 1300 differs from a 100 Balance Mower, but there are 2 pictures of my fast hitch setup on the Implement Photos here. Just search on the word 'balance' and you'll find my pictures.
