Hydrolics
J.P.
06-11-2004 22:11:39
I have a Super A. Im finding out from you guys why it doesnt have power. Thanks. Next problem. The hydrolics... when i attach the 4'cutter, the hydrolics jumps up and down. Ive replaced the fluid, bled the air out, but it still jumps. I dont see any leaks. Any suggestions? Could it be caused by my tractor not having the power that it should have?
Hugh MacKay
06-12-2004 02:39:01
 Re: Hydrolics in reply to J.P., 06-11-2004 22:11:39
JP: Does it do this while lifting or just when the hydraulics are up all the way? If it is just when hydraulics are up all the way, try leaving the lever back a bit to see if it will stop doing this. If that works then the lever just needs adjustment. If it continues to jump the touch control probably needs a kit.
