300 fast hitch assy
eric
06-12-2004 18:22:05
I have a farmall 300 built in 1956 it has a fast hitch with traction control and the pilot guide gauge is this correct or was the 350 and 450 the first tractor to come with this could my 300 came with it or did someone add a later fasthitch to it
thanks in advance eric
Aberdale Farm
06-13-2004 04:50:19
 Re: 300 fast hitch assy in reply to eric, 06-12-2004 18:22:05
eric,
Hugh may be right, it could possibly be an update. I have asked the same question about my 300 FH. Mine is like yours, pilot guide and all, and it sure looks original, but who knows?
Dale
Hugh MacKay
06-12-2004 19:42:32
Eric: Looking at the production numbers there were probably a lot of 300 built in 56. Do you know from serial number if yours was one of the last 300 built. It could be an add on, however with IH's reputation for accuracy on just when new items came about, I wouldn't bet money that it didn't come from factory as it is.
grammarguy
06-12-2004 18:31:21
..... .wow, that may just be the longest sentence of the year..... ...if not, it is certainly in the running..... ...the drawing will be held on jan. 1, 2005..... ...good luck
Bob
06-13-2004 01:08:15
 Re: Re: 300 fast hitch assy in reply to grammarguy, 06-12-2004 18:31:21
Study your statement.
Hugh MacKay
06-12-2004 19:32:18
Well grammerguy, he explains his situation quite well. If you knew as much about the Farmall 300 as you think you do about grammer you may have been of some damn use.
gene b
06-13-2004 03:42:36
 Re: Re: Re: 300 fast hitch assy in reply to Hugh MacKay, 06-12-2004 19:32:18
WELL SAID HUGH
Smuckatell'e
06-13-2004 04:44:07
 Re: Re: Re: Re: 300 fast hitch assy in reply to gene b, 06-13-2004 03:42:36
OK Grammer guy what did you learn? I Assume you're new here on the site? So maybe you didn't know that poking fun at HUGH MACKAY is never allowed no matter how justified. At least you didn't challange him on the content of his message. Boy then you would be in big trouble. LOL
Hugh MacKay
06-13-2004 06:44:20
 Re: Re: Re: Re: Re: 300 fast hitch assy in reply to Smuckatell'e, 06-13-2004 04:44:07
I guess you can't figure out timing of posts, grammer guy was in there before I. I think he was poking fun at the original post. Maybe he should poke a bit of fun at those who can't read.
