Super A found a block
VAJerry
06-13-2004 08:11:18
Its from a 130. Cannot beat the price. Question will my crank shaft and cam/lifters work in this block?
Stan(VA).
06-13-2004 19:55:59
 Re: Super A found a block in reply to VAJerry, 06-13-2004 08:11:18
A 130 should be OK. Crank and cam should be fine. The 140/240 block would not fit. Look at the front of the block just in front of cyl #1, and verify that it looks like your old one, and that it doesn't have a large flat machined with a water jacket opening for the new style water pump. If so, that would interfere with your upper radiator neck/thermostat housing and fan mount. The 130 block should be machined for the smaller sleeves (ie: A/B/C/early Super A) with the 3 5/16" OD at o-ring seal. So depending on the serial number of your Super A, the sleeves might not interchange.
Stan(VA).
