Farmall A Battery Size and Cable Lenghts Needed
Tim
06-14-2004 16:19:48
I am putting a '45 Farmall A back together that had a cobbled up starting system.
Does anyone know what size/group the proper 6 volt battery is? I also need to know the proper lengths for the cables. I know the negative goes to the starter but don't know where the positive ground was originally hooked up...?
Thanks in advance, Tim
Kurow
06-14-2004 22:24:09
 Re: Farmall A Battery Size and Cable Lenghts Neede in reply to Tim, 06-14-2004 16:19:48
The book shows the ground to be onto the nearest transmission cover. Note.
Get good quality cable and ensure you get really good contacts. Scrap off the paint/rust etc.
No point getting cable longer that required.. Measure up with a piece of string 1st.
