farmall super c oil pressure
john in ohio
06-14-2004 16:21:44
the oil pressure gauge (new) shows low oil pressure when the tractor gets warmed up. I put a new pump screen on, thinking it would help some but didn't. I am wondering if I need to rebuild the oil pump or is there some way to adjust the current pump so there is more pressure.
thanks in advance, john
TDK
06-15-2004 09:49:21
 Re: farmall super c oil pressure in reply to john in ohio, 06-14-2004 16:21:44
Just tore down pump on a 169 engine. Oil pressure was pretty good considering condition of crank and bearings.Replaced brgs. and reground crank. Took pump apart, bottom was warped & gears had worn into it. Took a little while on the belt sander to get it flat again. Hope to find out the results in a few days.
G Cole
06-14-2004 17:43:12
Had the same problem. When I took the pump apart I found the bottom plate was warpped. It would let the oil blow out instead of pumping it. The gasket was also shot. I laid the plate down flat on some sandpaper and lept moving it back and forth until it was level. I now have 65 lbs. Watch the gasket size. VERY important. Got my info the same way. Does yours have a 2 point?
john in ohio
06-14-2004 17:51:02
 Re: Re: farmall super c oil pressure in reply to G Cole, 06-14-2004 17:43:12
thnks for the info. i will try that when i get a chance and see if that works.
i don't have a 2 point, but would like to find one sometime. i am going to look for one this week at a show.
Owen
06-20-2004 17:14:39
 Re: Re: Re: farmall super c oil pressure in reply to john in ohio, 06-14-2004 17:51:02
I have repaired many oil pumps like the Super C use by sanding the bottom plate flat and then reshimming with the correct gasket thickness. I also add a steel bar accross the plate where it had warped. I start with a piece about 1/2 x 1/4 the proper length and drill hole to match those on the pump. A little grinding is necessary to firt the plate. Assemble with longer bolts. I have never had a failure on a pump with this added
