1066 injection pump problem
jim in ny
06-14-2004 17:38:29
our 1066 has a problem with the govenorwhen the tractor gets good and warmed up the govenor seems to let the rpms just go crazy . anybody know of a fix short of taking pump to shop or buying reman? any help appreciated thanx
Chuck's Repair
06-14-2004 18:57:36
 Re: 1066 injection pump problem in reply to jim in ny, 06-14-2004 17:38:29
The friction springs that control the tension between the governor weights and the governor shaft have worn to the point that the weights now spin easilly on the shaft and are not able to expand at higher RPM's and shut the fuel down.Unfortunatly there is no easy fix.The governor housing has to be removed so that shims can be transfered from one side of the weight assembly to the other to increase spring pressure and restore the breakaway torque that the manufacture has established for that pump.It's not that hard of a job but you will need a service manual.
