Could really use a quick answer, 300 Utility.
Loren
06-14-2004 21:02:01
On the transmission driveshaft bearing cage (#65 in I&T manual, housing that holds the planet carrier for the TA) there is what looks to be a drain port for the bearing lube. Mine was pointing up, is this not a drain port that points down? Loren
Dave W V
06-15-2004 02:32:26
 Re: Could really use a quick answer, 300 Utility. in reply to Loren, 06-14-2004 21:02:01
Place it to match hole in trans. case, when clutch housing bolts to trans. housing.
Loren, Thanks Dave.
06-15-2004 11:35:20
 Re: Re: Could really use a quick answer, 300 Util in reply to Dave W V, 06-15-2004 02:32:26
I didn't see that hole before. That's what I needed. Thanks again.
