Super M Live Hyd. Pump
Paul G. in Mn
06-15-2004 13:22:38
I picked up a used Super M live Hyd. Pump and after I got it I was told that the gas version and diesel turn the oposite way. Is that correct? If so how do I tell which one I have? Also I picked up a frond cover from a 450 but the pump didnt have a gear on it. I am going to put it on a 39 M, can I use the gear that is driveing the distributor now or do I need to get a different one? Is there a good place to get a manifold that the hoses screw into and that bolts to the pump? Any thing I need to watch out for when looking for a manifold?
Duner Wi
06-16-2004 18:38:53
 Re: Super M Live Hyd. Pump in reply to Paul G. in Mn, 06-15-2004 13:22:38
I think the timing gears were made stronger in the live pump models. I broke timing gears in my "M" after putting live pump in.
Dave WV
06-15-2004 16:53:55
You can use the same gear. Diesel pump bolt pattern is a little different than gas. If you have diesel pump bolt holes wouldn't match your cover.
