Need help locating a part
Mike in CT
06-15-2004 14:53:19
I'm attempting to bring a 41 h back to life. Working on the magneto now, went to put all my new parts inside the mag and come to find out the piece that holds the coil in is missing. It appears that there must be a tube of somme kind that slides through the coil and gets screwed in with the a screw on each side. I can't be certain because this is the first magneto I've ever worked on. This seems to be a common theme with this tractor... all the desirable items have been stripped. If anyone has one they wouldn't mind parting with for a few bucks let me know.
Thanks.
Mike
Geoff NY
06-15-2004 16:42:22
 Re: Need help locating a part in reply to Mike in CT, 06-15-2004 14:53:19
The coil has the bar running through it with threaded holes. Most parts suppliers have them.
JON
06-15-2004 18:56:15
 Re: Re: Need help locating a part in reply to Geoff NY, 06-15-2004 16:42:22
That is a special part made of lamenated steel so dont try to use just anything. JON
