Clutch rusted to flywheel. Now What ???
Red Rookie
06-15-2004 18:28:21
I just bought a 240U with only 616 hours on it. Been sitting inside for the last 8 years. Clutch is apparantly rusted to the flywheel. What is the best way to break it loose short of splitting the tractor? I'm new to IH. Just sold my JD B. Thanks for any help you can give me.
Nigel Mc Hugh
06-22-2004 09:01:58
 Re: Clutch rusted to flywheel. Now What ??? in reply to Red Rookie, 06-15-2004 18:28:21
Hi Guys, Like the idea about pushing it off the axle stand. Had a JD 2950 done this, tried all the usuall stunts, driving around, revving up and down etc but nothing worked. Finally in desperation I removed the starter, propped down the clutch, positioned a heavy bar up against the flywheel and give it a good belt of a sledge hammer. Sounds brutal but it worked with 1 wallop, did no damage to the flywheel either. Nigel.
Clara
06-16-2004 03:26:53
This has never failed me. Put one rear wheel up on jack stand. Start engine. If not outside, open door, give it 1/3 throttle. Have a helper push it off jackstand.
Allan in NE
06-16-2004 03:38:37
 Re: Re: Clutch rusted to flywheel. Now What ??? in reply to Clara, 06-16-2004 03:26:53
Hey!
Well, that's some darned good thinking! Would a guy hold the clutch in while doin' this?
Thanks,
Allan
Dan
06-15-2004 22:28:41
I had that problem on a JD MT I picked up. Got it loose but it didn't all come loose together so had to split it anyway. Good luck.
Wayne
06-15-2004 21:48:24
I had the same problem with a tractor that I recently purchased. Drive it around in 2nd or 3rd gear and alternately apply brakes and clutch pedal. Mine broke loose after about 10-15 minutes. Good Luck!
Ken
06-15-2004 19:52:13
My brothers 74 Gremln used to do that. He would start in 1st gear and speed shift it to 2nd and then tap the throttle until it broke loose.
Spencer
06-15-2004 18:42:09
I don't know if this will work but if ya hook it up to something that it can pull and put it in gear then start it, but make sure ya push in on the clutch because it won't have the pressure plate pushing on it. You still would be a good idea to change everthing though.
Let me know if this works
Spencer
JON
06-15-2004 18:49:54
 Re: Re: Clutch rusted to flywheel. Now What ??? in reply to Spencer, 06-15-2004 18:42:09
I have seen a neighbor with a big A4T with that problem he put it in 3rd started it and ran around the field with the clutch in throttleing it up and down untill it broke loose. I had a chevy truck that used to do the same thing but I used low gear. JON
Allan in NE
06-15-2004 19:02:21
 Re: Re: Re: Clutch rusted to flywheel. Now What ?? in reply to JON, 06-15-2004 18:49:54
JOon,
Is this a regional problem?
I've been twistin' wrenches all my life and never heard of this until I started reading all the guys' posts about stuck clutches here on this site.
'Course, I live out here in the semi arid region too.
Thanks,
Allan
John Ne.
06-15-2004 20:02:08
 Re: Re: Re: Re: Clutch rusted to flywheel. Now Wha in reply to Allan in NE, 06-15-2004 19:02:21
Allan, seen it mostly on old stuff sitting out for a few years. dealt with about 3-4 of them myself. lots of moisture here on the east coast of Nebraska. Where are you?
Allan in NE
06-16-2004 02:19:57
 Re: Re: Re: Re: Re: Clutch rusted to flywheel. Now in reply to John Ne., 06-15-2004 20:02:08
Hi Jon,
It is really strange that it is so wet in some regions and so dry in others. Lots of folks out here have been irrigating alfalfa for two weeks now.
The young fella who rents the farm has already run the pivot around on the corn. It is so dry out here!
I live way out here in the opposite corner; 25 miles from SD and 80 from Wyo.
Allan
