in-line fuel filter
William Ransom
06-16-2004 18:18:50
Today, I installed a fuel filter in the M's gas line between the sediment bowl and the carburetor. In 1997, my father cut out a short piece of the gas line near the sediment bowl and replaced it with a rubber hose. The rubber hose was just long enough to connect the parts of the gas line, and with the hose that is on it, the filter can only be installed almost horizontally. There is some air trapped in the filter -- the end where the gas goes out is slightly lower than the end where it goes in, and the filter is a little less than half full of gas. Is this a problem? If it is, what can be done about it? Do I need more rubber hose for it? Also, a little gas leaks out around the gas line where it connects to the sediment bowl.
Dave in CT
06-17-2004 07:40:33
 Re: in-line fuel filter in reply to William Ransom, 06-16-2004 18:18:50
The air in the fuel filter is O.K.. I've tried to memorize where the fuel line is when gas is flowing freely so I can tell if anything is getting clogged up. If you have one of the disposable plastic fuel filters, you could even draw a line along it with a sharpie.
I assume the little leak is where the metal fuel line screws into the sediment bowl/valve. You could wrap the threads with nylon tape before screwing the fitting in to try to stop it. If it's where the rubber hose fits over the metal fuel line, a small hose clamp should do it.
Allan in NE
06-16-2004 18:26:46
WIlliam,
Don't worry about that "trapped air". All of those inline filters do that.
Allan
