Help with Dating 140
Bill B
06-16-2004 19:47:51
Looked at a Farmall 140 for sale today. Its serial number was 59685. The owner did not know the tractor's age. It is being sold with cultivators and fertilizer rig. The paint is faded and the generator was replaced with an alternator. The hydraulics work fine. The pto works fine. The deluxe seat needs recovering. The engine runs well and has good oil pressure. It has a single point hitch and a front brush guard. It has rear wheel weights, but no front wheel weights. The owner wants $5000 for everything. Here in NC these little Farmalls bring more $$ than big tractors.
Questions:
1) What year is this tractor?
2) The tires are mostly worn out. Approximately what would a full set of tires cost?
3) Where do you go for single point fast hitch implements like a turning plow and double gang disk harrow? Or do you buy 3 point hitch versions and adapt to single point?
Thanks in advance for your advice,
Bill
Ramon
06-24-2004 14:00:29
 Re: Help with Dating 140 in reply to Bill B, 06-16-2004 19:47:51
Bill, Drop me a line. I am going to sell some of my extra Fast Hitch equipment. Ramon
Ramon
06-17-2004 19:56:51
Bill, Drop me an email. I live in Durham and just got a Farmall 100 but in my search, I found several sources of Fast Hitch implements and can probably answer some of your other questions. If you have a picture of the bumper and how its mounted on the 140, I would be much obliged. I just got a bumper and have been looking for different mounting options... Cheers Ramon (rtancinc (at) cisco.com) at=@
Dating 101
06-17-2004 18:24:51
Start slow and be a gentleman. Open the door for her and so on. None of this "slap on the rear end" business.
Broke 'n' Dumb
06-17-2004 06:29:46
Just don't expect a goodnight kiss when you take her home...
Buy her flowers
06-17-2004 06:08:49
:o)
Jim in NC
06-17-2004 03:48:35
It sounds a bit high to me, especially since the tires are in poor shape. Check out the Agricultural Review. There are often several in it each month. I know of 2 that have been sold around here (near Greensboro) in the last year for around $4000.
Stan(VA)
06-16-2004 20:47:59
1- 1976
2- $300-400 or more depending on quality, mounting labor, new/used tubes, fluid, bad rims,...
3- Try agri-supply in NC. I've been to their VA store and they carry new fast hitch implements. You can also use 1 to 3 pnt adapters. Apparently they have store sthrough the carolinas, and GA I believe.
Stan(VA).
