574D
TGIN
06-17-2004 04:24:46
Planting hay a few yrs. ago the engine built up enough pressure that it blew the valvecover gasket into small pieces , blew the seals out and blew the dipstick about 15 or 20 ft. Well I`m fixin to tear into it and was looking for ideas to what happened . The eng. was on about a 1 yr. rebuild . The vent tube is not pluged .
Randy in NE
06-17-2004 04:32:15
 Re: 574D in reply to TGIN, 06-17-2004 04:24:46
Like they say: "A picture is worth a thousand words". With out us knowing more or seeing it it would be hard to guess. You are going to have to tear it apart and inspect everything. At that point you will be able to identify the cause. I would be pulling the top and bottom off and checking fluid levels as I take it apart. It takes a lot of pressure to blow a valve cover apart. A properly workig vent tube will allow more than enough air to escape to prevent this kind of pressure build up. Take it apart is see what you find.
richard
06-17-2004 16:34:40
 Re: Re: 574D in reply to Randy in NE, 06-17-2004 04:32:15
Have seen this before many years ago with a Ford engine in a Class combine,The oil level dropped allowing the oil fumes in the sump to get hot enough to ignite,similar damage to what you describe,this was due to a leaking seal on the oil filter bowl.We had sold 7 Class combines with Ford engines,all of them were converted to Perkins within 6 years or so.
