SMTA photos and questions
Keith
06-17-2004 12:12:44
Here are some photos of my SMTA's hydro set up and starter. What kind of power steering is this? Also, should it have a valve in the lines for the steering? I dont know anything about the SMTA's and never been around one in person. So anything you can tell me will be a big help. I think the starter is from a 400, but not sure.
Thanks,
Keith
Bob M
06-18-2004 08:40:33
 Re: SMTA photos and questions in reply to Keith, 06-17-2004 12:12:44
Keith – I took another look at your photos. Hard to tell for sure from the pix but I don’t see a flow divider valve either. And if the flow divider is missing Dan’s observation is right: The power steering can’t work - unless the Liftall lever is pulled back and locked and the 3 Liftall hyd outlets are all dead headed. Otherwise the system will not develop pressure to work the PS unit.
Is the PS functioning on your tractor now?
Dan
06-18-2004 07:27:39
Re the starter, I would assume this has been changed over to use a push button instead of a rod to engage starter. I changed the starter on my SMTA over to push button but didn't mount the silinoid on top of starter. Is this still 6 volt? I don't see a priority valve in the system. The PS wouldn't work if you tried to use the lift all would it?
Keith
06-18-2004 10:41:22
 Re: Re: SMTA photos and questions in reply to Dan, 06-18-2004 07:27:39
No, it has a 12V battery now. The coil still reads IH 6V though. I assume that it needs a resistor to the coil.
The PS does not work right now. The lift all was very low on oil when I got the tractor and I havent filled it up yet. Going to fill it up today and see how it works.
Bob M
06-18-2004 10:49:50
 Re: Re: Re: SMTA photos and questions in reply to Keith, 06-18-2004 10:41:22
Your assumption about the resistor is correct! If there's not a ballast resistor in series with the coil primary you need to add one. Otherwise the points will burn up quickly. Also you could overheat and ruin the coil.
Bob M
06-17-2004 12:33:10
Keith - That’s an aftermarket Charlynn PS setup. No external valving is required aside from the flow divider valve located in the pressure line before of the 4 way remote (the "Christmas tree") valve inlet. Punch below for a scanned copy of the original installation instructions for the Charlynn installed on my Super M.
The Charlynn is a good system – reliable and steers nice. Mine was installed about 30 years ago and it still works great!
That starter could have come from any number of tractors – including I think a 400.
