'45 IH A
Tony
06-17-2004 16:20:58
Recently became the owner of a '45 model "A"and I don't have a book.
It runs fairly well but I want to check the timing.
Is the front cylinder number "1" ??
Where is the "timing mark"??
Thanks
Tony
gene b
06-18-2004 02:43:14
 Re: '45 IH A in reply to Tony, 06-17-2004 16:20:58
If you have a magneto you are in time as they fire on T.D.C. After engine starts timing goes to 34deg advance. This is the way the mag works. Does the engine start and run now or are you having trouble getting it to start?
parts man
06-17-2004 16:43:13
Tony, yes, the front cylinder is #1. The timing mark is on the back side of the flywheel. Yiou see it by taking the inspection cover off the bottom of the bellhousing, and shine a light up through.
Tony
06-17-2004 16:56:41
 Re: Re: '45 IH A in reply to parts man, 06-17-2004 16:43:13
Thanks parts man, I have been looking on the front of the engine!!!
Thanks again
Tony
