PULL OR NOT TO PULL
Jeff
06-17-2004 16:28:01
OUR NEIGHBOR WANTS TO PULL,HIS FORD 4000 AGAINST I.H. 544 HYDRO,I SAY BELLY UP,LETS ROCK,,,HAVE I OVER EXTENDED ?
Jed`
06-18-2004 07:00:29
 Re: PULL OR NOT TO PULL in reply to Jeff, 06-17-2004 16:28:01
I am an IH guy at heart, but you bite off more than you are going to be able to chew. Good luck though.
Novel Idea Guy
06-18-2004 06:35:27
That's a good way to get hit in the head with a broken tow chain...
Nothing against IHs, but a 544, and a hydro nonetheless, is not the tractor I'd choose to represent for the red crowd. The Ford will walk away with you because 544s are gutless in the first place, and the hydro will slip.
Jeff
06-18-2004 08:50:14
 Re: Re: PULL OR NOT TO PULL in reply to Novel Idea Guy, 06-18-2004 06:35:27
Thanks for all the responses,i am way yonder to old(been around) to pull with a tow chain,going to use cable i have winched d-9 out with,i may have bit off more than i can chew,i will tell either way on here tonight,(i don't think i have),the 4000 is right at 54 ponies,the 544 is pulling above 55,but they are 55 red horses!i would not even accept the pull if it was not for his wise___ son's mouth.i told him to belly up,my money is on Red,post results later,,,thanks-Jeff
Cmore
06-17-2004 21:00:18
Your probably in bad shape. Your Hydro will slip and whine. Gear drive Ford might get you. If gear drive, no problem for you, but Hydro, BIG problem....Cmore
Chris Brown
06-17-2004 19:20:51
hook it up and tear him a new ford hole. A 544 hydro weighs in at 6600 lbs and a ford 4000 weighs 3610 if it is the newer 3 cyl one and it weighs 4400 if it is the old 4 cyl one. Let that old binder stretch him out.
MR BILL NO.MN.
06-17-2004 18:17:39
Ford will win every time. lol
