Help ID with cultivator
JohnG(TX)
06-17-2004 17:10:43
I have part of a cultivator, and one cast part has a part number 511983R1 or 50983R1. Thanks.
crockofbc
06-18-2004 08:16:24
 Re: Help ID with cultivator in reply to JohnG(TX), 06-17-2004 17:10:43
Part number 511983R1 is called a rear gang beam bearing. It's actually the part that bolts to the rear axle housing that the left rear gang attachs to. You have part of a Farmall Cub cultivator. Your other part number is missing a digit. Go take a look at the TM tractor parts implement hookup page for some good pics of a cub cultivator. The pics you want are under the cultivator - rear gang beam assembly link.
JohnG(TX)
06-18-2004 08:42:41
 Re: Re: Help ID with cultivator in reply to crockofbc, 06-18-2004 08:16:24
That's it!!! I believe I have the entire front and rear sections. I had no idea it was for a Cub though. It was in a pile that contained stuff for an M/SM/400. Any idea what it would be worth? I don't have a Cub, but a friend does.
JG
crockofbc
06-18-2004 08:18:46
sorry, didn't add the link
http://www.tm-tractor.com/gim/gim_001.htm
riverbend
06-17-2004 19:53:38
John,
That is not much to go on. Got a photo ?
