Super C gear noise
ELMER
06-18-2004 06:51:24
My super c has a high pitch gear noise in 1st and reverse,mostly in reverse. Not continual but half the time. Anybody got a clue? Thanks
tractorhead
06-19-2004 06:35:29
 Re: Super C gear noise in reply to ELMER, 06-18-2004 06:51:24
Hi Elmer; my A is was very noisy in reverse and first after looking and looking I determined that the reverse idler had too much wear,so I changed it, its ok now.thats the only gear you can change from up above it was easy. jimmy
farmerjohn
06-18-2004 20:06:56
One of my childhood memories of growing up on the farm was the soothing high pitched hum from our super C as Grandpa drove it around and I rode on the trailer behind. That was 30 years ago, I had the tractor totally rebuilt and restored two years ago and the transmission was fine.
Peabody
06-18-2004 08:56:32
I got the same, mostly in 1st. Everybody I've talked to said don't worry about it, just live with it.
Randy in NE
06-18-2004 07:26:14
Would suspect gear wear. Could be a bearing going out. One of my C's has quite a growl in 3rd gear. I have never gone in to look at it. Suspect that it is due to gear wear. If I ever get to the point where I total go through my tractor then I will investigate it at that time.
ELMER
06-18-2004 09:47:16
 Re: Re: Super C gear noise in reply to Randy in NE, 06-18-2004 07:26:14
Thanks guys. Feel better already
