350 block interchange
Keith
06-19-2004 07:32:26
Found a 350 gas in the weeds the other day. It's mostly complete but has a hole in the block from a rod coming lose. Will a H or 300 block interchange? I believe the 350 head is still useable but, unsure of the crank. Any help will be appreciated.
Thanks,
Keith
Dave W V
06-19-2004 10:01:36
 Re: 350 block interchange in reply to Keith, 06-19-2004 07:32:26
Both will work but use 300 block to use same size
piston and sleeve as 350.This refers to block change only,if switching complete engines not all H timing covers accept hydraulic pump bolt pattern.
