Hydro 186, Can I use a remote Hyd motor?
Dennis Hartlaub
06-19-2004 11:32:13
I need to run Hyd sprayer pump with my Hydro 186, will this be a problem?
Bob
06-19-2004 19:30:27
 Re: Hydro 186, Can I use a remote Hyd motor? in reply to Dennis Hartlaub, 06-19-2004 11:32:13
Dennis,
I believe the hydraulic cooler on these tractors is marginal, at best, in hot weather.
Make sure the cooler, as well as the radiator, are clean for good airflow, and that the fanbelt is in good condition, and TIGHT.
If you intend to use this for long hours at a time on HOT days, be carefull of your hydraulic temperature.
Aces
06-19-2004 16:19:18
Dennis not any more than other tractor you have to make sure you have right motor and not get it hot.
