Farmall Regular Oil leak
Harold
06-20-2004 07:38:57
The engine was started after many years of non use. After 30 minutes of running a noticable oil leak developed between the block and the bell housing.The leak appears to be in the area of the camshaft. Any idea's to the cause and what it will take to repair?
JEFF
06-21-2004 09:17:59
 Re: Farmall Regular Oil leak in reply to Harold, 06-20-2004 07:38:57
Needs a new gasket. Loosen the bell housing enough to get in there. You'll have to cut the gasket at the top to get it around the crank. Its not easy to pull one of those old flywheels, so I would avoid it if you could. You can also stick the right sized o-ring in there at the end of the cam. I just gave mine a good dose of silicone and it fixed the leak.
Harold
06-21-2004 09:35:35
 Re: Re: Farmall Regular Oil leak in reply to JEFF, 06-21-2004 09:17:59
Jeff
Sounds like a plan, thanks
Harold
