Order Farmall Cub Parts Online
Cub 154 Crankshaft Pulley
Larry Hardesty
06-21-2004 05:47:11
I just got back my Cub 154 from Case-IN dealer from fixing rear seal. Started fine to load and unload off trailer. However, now it appears to turn over crankshaft pulley but not turn over engine. Is there a key or something that might be bad that holds crankshaft pulley to crankshaft..or some other common problem? If so, how hard to fix?? Any help appreciated.
Novel Idea Guy
06-21-2004 13:44:55
 Re: Cub 154 Crankshaft Pulley in reply to Larry Hardesty, 06-21-2004 05:47:11
I would take it up with the Case IH dealer that worked on it for you.
Larry Hardesty
06-23-2004 17:28:49
 Re: Re: Cub 154 Crankshaft Pulley in reply to Novel Idea Guy, 06-21-2004 13:44:55
I took it back, sheared key on the shaft. Dealer fixed it and did okay by me. Thanks
